If it is leaking coolant in the vehicle, the heater core is likely the cause. It is located under the dash on the passenger side.
First, look under the dash at the HVAC box. See pic 1. The heater core is located in the heater box. There are two hoses that will attach to it from under the hood at the firewall. Make sure they aren't leaking. If the bottom of the heater box is wet, the core is my first suspect.
To get you started, here is a link that explains in general how one is replaced. You can use this to help.
https://www.2carpros.com/articles/replace-heater-core
Let me know if that is where it is coming from. If it is, I will provide the directions specific to your vehicle for replacement. However, it will require the removal of the instrument cluster, and the AC will need evacuated and then recharged when you are finished.
See pic below.
Jul 13, 2022 at 11:14 PM
