What I have are the directions for removal and replacement of the expansion valve right from alldata. Take a look through the specifics to see if you did it correctly. The attached pictures correlate with these directions.
REMOVAL AND INSTALLATION
1. Disarm airbag system as outlined under Airbags and Seatbelts.
2. Recover refrigerant.
3. Remove blower unit, as follows:
a. Remove glove compartment.
b. Disconnect ECU electrical connector, then remove ECU and bracket.
c. Disconnect connector bracket electrical connector, then remove connector bracket.
d. Disconnect blower unit electrical connector.
e. Disconnect air inlet damper control cable.
f. Remove blower unit three attaching screws and nut, then remove blower unit.
4. Disconnect and cap evaporator liquid and suction tubes.
Removing Evaporator Case Cover
Removing Evaporator Core
Removing Expansion Valve
5. Remove evaporator cover.
6. Remove evaporator assembly, then separate evaporator and expansion tube.
7. Reverse procedure to install.
8. When new evaporator is installed, add 1.6 oz. refrigeration oil.
TORQUE VALUES
Expansion Valve To Evaporator: 4.8 lb.ft. (5.4 Nm)
Refrigerant Tubes: 7 lb.ft. (9.8 Nm)
I hope this information is helpful. Let me know if you have other questions or need additional help.
Aug 3, 2018 at 9:03 PM
