Leaking brown fluid under the engine
2004 CHEVROLET TRAILBLAZER
117,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
ZACK.LYONS2326
Leaking brown fluid under the engine has a weird smell and when wet looks like a rainbow. the engine oil level is high.
Jun 13, 2019 at 11:59 AM
Welcome to 2CarPros.
What you described is oil. However, my concern is why the oil level is high in the engine. When you check the oil, does it have a fuel smell? Is there any evidence of a tan creamy substance in the oil?
If there is a fuel smell, we may have a problem with fuel pressure or a leaking injector. However, if you see a tan creamy substance, it may be coolant mixing with the oil as a result of a bad head gasket. Is there any white smoke from the exhaust?
Take a look through these links and let me know if anything seems to mirror what you are experiencing other than the oil leak.
https://www.2carpros.com/articles/excessive-smoke-coming-from-the-exhaust-pipe
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Also, when you check the oil, smell the oil on the stuck to see if it smells like gas.
Jun 13, 2019 at 12:17 PM
