Leak (Coolant) In The Back Of The Engine, Coolant Flange Is What I Got...
2003 VOLKSWAGEN PASSAT
160,000 MILES • 1.8L • 4 CYL • TURBO • AUTOMATIC
ITSKEVN007
  • 15 POSTS
My car has been leaking coolant through the back of my engine. Sometimes I see that my coolant level is low, and that there is a puddle on the floor. From doing some research, the coolant flange is the only issue that meets the problems I have. Now I'm here to ask if there is a simple way to repair a coolant flange (DIY) and what parts will I need? I apologize if I ask too much, just trying to save some money.
Kevin.
Jul 21, 2014 at 9:36 AM
SATURNTECH9
  • 30,869 POSTS
If the coolant flange/pipe is leaking it will need to be replaced you cant repair it.The plastic overtime and heat becomes brittle and cracks and leaks.Its not the easiest to replace its about a 3hr labor charge or so to have it repaired in the shop.Its pretty common for them to leak we have them in stock at the vw dealer I work at thats how common they leak.
Jul 21, 2014 at 8:27 PM
ITSKEVN007
  • 15 POSTS
Thanks for the reply and how much do you believe is the cost to do this work if I do take it to a shop?
Kevin.
Jul 22, 2014 at 9:26 AM
SATURNTECH9
  • 30,869 POSTS
Depends on the labor rate they charge times 3hrs the labor rates vary from shop to shop.The part is under 30 from what we charge for it at the vw dealer.
Jul 22, 2014 at 9:57 PM
