It looks like power steering fluid on the concrete to me.
I see the fluid all over that side of the engine near that dipstick and squirting out.
I would remove the serpentine belt, so that would stop the power steering pump from pumping and see if the squirting stops.
Does the fluid on the ground smell like the power steering fluid in the pump?
The high pressure line at the back of the power steering pump can be squirting out this fluid. Check if the line is cracked, loose or if there is a seal, check the seal so you will have to remove the high pressure line from the back of the pump and check the seal.
Mar 30, 2018 at 5:10 PM
