Daughter noticed there was a small amount of antifreeze on top of motor. Radiator/reservoir is full.
Thanks,
Carla Reed
Image (Click to enlarge)
Nov 23, 2018 at 7:38 PM
CERTIFIED EXPERT
Good evening,
That could be the thermostat housing or the hose.
You need to have a pressure test done to pin point the exact leak. Once that is done and the leak found, let me know what the failure is and I can advise you on the repair.
