Do both sides do this? Clearly the spring should feel solid and not move much at all so I suspect it is broken at some point. You want to inspect the entire pack and see if you can find where it is broken. I attached a picture of a dramatic case but it will be the idea.
The shackles there that you mentioned in your other post are only intended to keep the leaf springs from fanning out so they are not the issue.
Thanks again for getting this new post started. I understand it may seem silly but the internet search engines actually punish the websites when they are not separated out like this which is why we require it.
Let me know what you find and we can go from there. Worse case, I would go to a salvage yard and get a new leaf spring pack.
Mar 20, 2020 at 2:49 PM
