2003 Range Rover engine light on
2003 ROVER RANGE ROVER
66,732 MILES • V8 • AWD • AUTOMATIC
DWAYNE WILSON
I was told by the landrover dealer i had to replace the dtml pump and its expensive, i got the pump but the mechnic i use cant seem to find where its located..
Oct 18, 2010 at 7:07 PM
DAVE H
  • 13,384 POSTS
MODULE - TANK LEAKAGE DIAGNOSTIC (DMTL)
NOTE:Before disconnecting the battery, ensure all text and cautions in the battery disconnection section are observed. See GENERAL INFORMATION, ELECTRICAL PRECAUTIONS.
Removal
Disconnect battery earth lead.
Remove RH rear wheel arch liner. See EXTERIOR FITTINGS, REPAIRS, LINER - REAR WHEEL ARCH - SINGLE.
Disconnect multiplug from DMTL. See Fig. 66 .
Remove bolt securing DMTL to body and release from clips.
CAUTION:Before disconnecting any part of the fuel system, it is imperative that all dust, dirt and debris is removed from around components to prevent ingress of foreign matter into fuel system.
Position DMTL beneath fuel tank filler neck for access. Remove and discard clip securing vent pipe to DMTL. See Fig. 67 .
Release vent pipe and remove DMTL assembly.
NOTE:DO NOT carry out further dismantling if component is removed for access only.
Plug all connections.
Release air filter pipe from DMTL.
Remove 3 Torx screws securing DMTL to bracket and remove DMTL.
Fig. 66: Disconnecting DMTL Multiplug
Courtesy of LAND ROVER NORTH AMERICA, INC.
Fig. 67: Removing Vent Pipe-To-DMTL Clip
Installation
Position DMTL to bracket and secure with screws. Connect air filter pipe.
Fit vent pipe to DMTL assembly and secure with new clip.
Position DMTL to body, fit bolt and tighten to 10 Nm (7 ft. lbs).
Connect multiplug to DMTL.
Fit RH rear wheel arch liner. See EXTERIOR FITTINGS, REPAIRS, LINER - REAR WHEEL ARCH - SINGLE.
Connect the battery earth lead.
Nov 5, 2010 at 4:32 AM
