2003 Range Rover brake pad sensor light
2003 ROVER RANGE ROVER
85,999 MILES • V8 • 4WD • AUTOMATIC
DRIEDMANGO
how could i turn off the brake pad sensor light after replacing rotor, pads and sensor
May 10, 2008 at 9:42 AM
DOCHAGERTY
  • 9,603 POSTS
If you replaced the pads and used new sensors then the resetting procedure should be as simple as leaving the key in the "run" position without starting the engine for a minute or so, that ought to do the trick.
Jun 7, 2008 at 2:51 PM
