1999 Range Rover front door locks
1999 ROVER RANGE ROVER
72,197 MILES • V8 • AWD • AUTOMATIC
BACKSPACE
we have a 99 range rover that came in with front power door locks inop. rears work fine. sill locking results in rears locking and only the front door used locking. tested wires from lock actuators to its door "out station", and from the out station to the BECM, all wiring is good.
this truck was towed in a couple of months ago with a no start condition. found that the BECM had changed its own coding and wasnt aligned with ECM. edited to the proper code and all was well. heater core is currently leaking and the lower wiring is wet. none of the plug connections at the BECM look wet. do you think it would be correct in condening the BECM - with the previous coding problem and now this - more so with the heater core leaking?
Aug 28, 2008 at 9:35 AM
DAVE H
  • 13,384 POSTS
if all wiring is in spec's suspect BCM
Jan 5, 2010 at 4:34 AM
