1999 Range Rover 1999 DEAD BATTERY, KEY STUCK IN IGNITION
1999 ROVER RANGE ROVER
145,000 MILES • V8 • 2WD • AUTOMATIC
TRICIATMR
I have had a dead battery for about 5 months. I charged it, maybe not enough, so when i went to start it, it wouldn't start and now the key is stuck in the ignition. never had any lock issues and no reason to think that i would now, feels 'locked' inside the ignition barrel.
Mar 1, 2010 at 8:54 AM
SERVICE WRITER
  • 9,123 POSTS
Did the engine turn over at all?
Battery must be at full charge. If the battery set through freezing weather it may be shot.
Mar 1, 2010 at 9:49 AM
TRICIATMR
No, it didn't. The alert for 'windows not set' went off and the alarm went off for about a minute, then it died. The battery is only a year old and has been dead, apparently for half that time. We've had cold weather but not really freezing weather. Why won't the key come out. I don't mind replacing the battery, but right now it's sitting out side, door slightly ajar (don't want it to suddenly lock with my only key in the ignition) and the key is in the ignition barrel, feels 'locked' in. Why won't the key budge?
Mar 1, 2010 at 10:00 AM
SERVICE WRITER
  • 9,123 POSTS
That is why the battery must be charged. There is a solenoid that needs to be activated for it to release. If you can jump the battery or get power to the battery from another one, it should release the key..
Mar 1, 2010 at 1:31 PM
TRICIATMR
Thank you!! That seems to make sense and I will work on getting my battery charged or replaced.
Mar 1, 2010 at 2:24 PM
SERVICE WRITER
  • 9,123 POSTS
You are welcome, post back if you need.
Mar 1, 2010 at 3:16 PM
