1997 Range Rover New Front Differential, but fear default s
1997 ROVER RANGE ROVER
MONICABOWSER
Shakes or Wobbles problem
1997 Range Rover V8 Four Wheel Drive Automatic 148k miles
I recently had a new front differential installed and went to pick it up at the shop and it was pretty shaky and the gear default light was still on- along with the fact that it is definately not changing gears smoothly. THe car is also idoling high, so from park to Drive it goes by itself. It seems to idol higher in park- which is wierd.
Oct 9, 2009 at 1:13 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
check for damaged/unconnected vacuum lines for the high idle .. but you need the repair shop to look at the vehicle again to find out why it is not running correctly and the light is still on ... you paid for a repair which has not been done correctly yet !!
Oct 12, 2009 at 4:19 AM
