Transmission problem
2002 Land Rover Freelander 6 cyl All Wheel Drive Automatic 70K miles
I have an 02 Land Rover Freelander with a transmission problem. Although only a couple times a day, when it needs to downshift into second gear it thuds. I have been told that third gear is not releasing rather than second gear not engaging. Instead of replacing the entire valve body I have ohms tested each of the solenoids. Some of them are high, but one is out of the range. The TCC solenoid measured 13.9 with an acceptable range of 12 to 13.2. I need to know if this measurement is out of spec enough to need replacement and if replacing this solenoid would fix the problem. The part is not expensive but getting to it would take a long time.
Mar 20, 2010 at 12:07 AM
