2002 Land Rover Freelander got lean code, dealer says repla
2002 LAND ROVER FREELANDER
98,000 MILES • 6 CYL • AWD • AUTOMATIC
POLARFOIL
My Service Engine Soon lamp was on and I needed a regularly scheduled service visit anyway so I paid them the outrageous $120 extra to diagnose. They said it was a "lean code" indicating a leaky manifold and the manifold would need to be replaced, estimated at $1500 for the job. Is this realistic? Should I get a second opinion (possibly for another $100 engine diagnostic fee)? Could it just be a loose bolt or old gasket?
Jan 5, 2009 at 4:42 PM
Get a 2nd opinion
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Jan 5, 2009 at 4:51 PM
