AT ABOUT 2500rpm THE TURBO KICKS IN, THIS HAS JUST SUDDENLY HAPPENED AND REALLY AFFECTED THE CARS BOTTOM END PERFORMANCE IS THIS AN EASY FIX?
Jul 28, 2010 at 1:24 AM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
You will have to check that the waste gate is not sticking open, this will bleed turbo boost, also have the inter cooler checked for a crack you can loose boost here but this will sound like a whistle or even a slipping belt type noise, start here.
