2004 Land Rover Discovery Brake lights
2004 LAND ROVER DISCOVERY
85,000 MILES • V8 • 4WD • AUTOMATIC
JTGARZA4
I recently noticed my left rear (upper) tail light was out on my Discovery HSE. It was on but would go out when I pressed the brake. So i replaced the bulb. The lights work now only they seem to be in bright ( brake mode) and all the time. When i press the brake the get only faintly brighter. When the lights are off and i press the brake they come on.
Also when the car is off and i press the brake my dash liights come on and will go off when i release the brake pedal. Not sure how to get things back to working normanally. Any advice would be most helpful.
Mar 9, 2010 at 10:19 PM
DAVE H
  • 13,384 POSTS
check/replace the brake pedal position switch and the light fitting ground/earth connections
Mar 12, 2010 at 6:43 AM
