2002 Land Rover Discovery 2 tc,abs
2002 LAND ROVER DISCOVERY 2
92,000 MILES • V8 • AWD • AUTOMATIC
OMARCAMARA
sirs, i have a 02' discovery 2 and i am having computer problems with no codes. i changed the tires and wheels and shortly after the traction control ,abs , and hill sign light are on . there are no codes as stated previosly when we run the code scan. please advise me as to what to check next. thank you,omar camara.
Jan 30, 2009 at 1:39 PM
GFIMOTORCARS
  • 673 POSTS
Omar when you changed the wheels and tires did you change the size. For example did you go from a 18" to 22" rim? If this is the case your vehicle may need to have the new tire and rim size entered into the traction control module. This is usually done at the dealer. Since the problem occured shortly after the new wheels and tires you can be pretty sure that this is the root of your problem. Also, if your vehicle is equipped with a tire pressure monitor, replacing wheels without corretly reinstalling the sensors can cause all sorts of issues.
Jan 31, 2009 at 12:42 AM
