2000 Land Rover Discovery 2 overheating
2000 LAND ROVER DISCOVERY 2
126,000 MILES • V8 • AWD • AUTOMATIC
MAURITIUS
good day
my vehicle has been running warm lately but not reaching the red zone. the other day on the highway it overheating with steam pouring out from under the hood. i opened the hood, and the upper radiator hose was disconnected thus there was coolant all over the engine, and thus an enormous amount of coolant gone from the reservoir. i got towed home, the next morning i really clamped down the hose, filled it with coolant, and drove around the block several times. the car started to overheat again, with now steam pouring out of the reservoir, and coolant really leaking out from beneath the reservoir, when i parked. i had put almost 2 gallons of coolant in the car, and a lot of it seems to be gone. i'm hoping this is a reservoir issue, and not a head gasket issue, or radiator. the reservoir cap screws on with a lot of difficulty, and what looks to be a overflow or relief valve drips coolant as i am filling the reservoir. any ideas as to where i should start? thanks very much
Jun 16, 2009 at 11:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The first thing you will need to do is get the cooling system pressure tested, this will show any external leaks in the system, replace the pressure cap and the thermostat, it would not be a bad idea to get the radiator cleaned & flow tested as well, start here and if this dose not solve your problem, we may have to investigate a head gasket issue, start with the simple things first,
Mark (MHPAUTOS)
Jun 17, 2009 at 1:38 AM
MAURITIUS
thank you mark, i will do as you suggest and follow up with the results
Jun 17, 2009 at 4:39 PM
