REMOVAL & INSTALLATION
ELECTRIC COOLING FAN
Removal
Release fasteners, remove battery cover and remove right turn signal. Release fasteners and remove left turn signal. Remove headlight access cover from body.
Remove screw securing turn signal to body and release light from 2 locating peg sockets in fender. Disconnect 2 connectors from turn signal and remove light.
Remove screws securing headlight finishers via access hole in wheel arch liners. Remove headlight finishers from grille. Remove 2 screws securing lower corners of grille. Remove 3 scrivets and remove grille.
Remove 2 bolts securing hood platform right support stay. Remove support stay. Disconnect connector from condenser cooling fan motor.
Remove 4 screws securing cooling fan cowl to mounting bracket. Remove cooling fan assembly and collect spacing washers.
Installation
Install spacing washers between cooling fan cowl and mounting bracket and secure with screws. Connect connector to cooling fan motor. Install hood platform support stay and secure with bolts.
Install front grille and secure with scrivets and screws. Install headlight finishers and secure with screws. Position turn signal and connect connectors.
Install turn signal to body and tighten screw. Install headlight access cover. On right turn signal, install battery cover and secure fasteners.
Jan 27, 2009 at 8:09 PM
