1999 Land Rover Discovery 2
1999 LAND ROVER DISCOVERY 2
DRED3232
Engine Performance problem
1999 Land Rover Discovery 2 V8 Four Wheel Drive Automatic
My landrover has a very rough idle and engine light flashing when i get over 50 mph the light seems to go out and run smoother i am getting two codes for gear ratio off in transmission and random cylinder missfire codes not usually the same cylinder i have changed spark plugs with no improvement this started a few days after i used bars leaks do not know if that could be related
Jan 17, 2010 at 6:53 AM
DAVE H
  • 13,384 POSTS
could you please supply the full fault codes .. this could be due to a faulty coil pack .. the coils supply spark to 2 cylinders at the same time !!
Jan 19, 2010 at 4:37 AM
