My car listed above has been having a lack of power and sputtering too often. Just not running like it used to. I have replaced the spark plugs; spark plug wires and the PCV valve. I noticed today that after disconnecting the battery the problem is intensified, lack power enough to almost stall if I don't give it enough gas and sputters in every gear for about 5 minutes or until after I get into 5th gear and/or over 60 mph, then it seems to be back to where it was before the battery disconnect. I am now thinking maybe I need to replace or clean the manifold pressure sensor (MAP) or replace the ignition coils, or maybe even something else.
Aug 20, 2024 at 4:33 PM
