Lack of power, and whirring sound in first gear
2000 MAZDA B2000
20,000 MILES • 1.7L • AUTOMATIC
KAGO TSIETSONYANA
The car get on over throttle on steeps. Also, it make a whirring sound on the first gear.
Sep 13, 2018 at 3:53 AM
Since there is a lack of power, the first thing I would suspect is a partially plugged catalytic converter. Here are two links. The first describes the symptoms of a bad converter and the second describes how to check it.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Next, is the check engine light staying on all the time? If so, you need to scan the computer to identify what trouble codes are stored. That will be very helpful in the diagnosis process. Here is a video that shows how to use one. I realize most people do not own one. However, if that is the case, most parts stores will scan it for you at no charge.
https://youtu.be/YV3TRZwer8k
Sep 15, 2018 at 7:27 PM
KAGO TSIETSONYANA
Thank you very much, your answer was much more helpful.I had discovered that it was the converter that was giving the problem.
Sep 17, 2018 at 2:36 AM
Great. I am glad you found the problem. Take care and let us know if you have questions in the future.
Sep 17, 2018 at 5:19 PM
