Labor hours for qualified mechanic to replace engine
2001 TOYOTA AVALON
220,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
SEVESTEVE
I realize the pros/cons of even considering replacing an engine in a car of this age and all of the associated risks. Can anyone tell me what the range of labor hours would be for a qualified independent and licensed mechanic (not a Toyota dealer) to replace the existing original engine with a 100 % compatible newer/lower mileage engine purchased from a reputable salvage yard?
Do not mean to be rude just looking for guess on hours, within a reasonable range. Thank you!
Oct 29, 2018 at 5:53 PM
CARADIODOC
  • 34,306 POSTS
Replace Complete Assembly Without Transfer Of Parts 12.4
Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment.
Complete Assembly With Transfer Of Parts 14.9
Includes: Transfer Of All Fuel & Electrical Units. Does Not Include: Transfer Of Optional Equipment.
Long Block 19.4
Includes: R&I Engine And Replacement Of All Necessary Components.
This is not how I'm accustomed to seeing times listed in standard Flat Rate guides. Normally they list the time for the basic job, then you're supposed to "Add XX.X hours with air conditioning", for example, and add additional tenths of an hour for each of a number of options that apply to the specific car. These times listed a rather high compared to domestic cars of that era, so something about this model makes the job relatively difficult.
Also be aware these times do not include handling rusty bolts that break off or become stripped or damaged, and parts that won't come apart due to age, rust, etc. For that reason, many shops don't go by the flat rate times for older vehicles. If a shop does give you an estimate based on flat rate times, ask what is and is not included for both parts and labor so there are no surprises at the end of the job.
Oct 29, 2018 at 6:37 PM
