Koeo stored codes 34 and 41 (no koer codes)
1992 FORD E-SERIES VAN
66,000 MILES • 7.5L • V8 • 2WD • AUTOMATIC
HAPLO
Reported check engine light was on, so I went to go pull the codes. 11 for the continuous (no issues) 34 and 41 for stored codes. Didn't come up on the KOER test.
Mar 23, 2019 at 10:55 AM
JOETECHPRO
  • 705 POSTS
Hey HAPLO,
We will need the full fault codes in the form P---- (eg. P1234)
The codes will have a letter, P is for power-train, and then four numbers.
Please reply with these codes and we will try and give you some further information.
Regards, Joe
Mar 23, 2019 at 1:43 PM
This is an OBD1 car so the codes are correct. EGR valve and lean which makes sense if the EGR is stuck open. I would remove the valve and use this video to test it.
https://youtu.be/DqUCbbKdWf4
Mar 23, 2019 at 4:04 PM
HAPLO
Good video! Thanks for the help Ken. Got about 80 miles on it now with no check engine light. Appointment for smog check next week. If you don't hear from me again, no news is good news. :)
Mar 23, 2019 at 9:56 PM
JOETECHPRO
  • 705 POSTS
Hey HAPLO,
Sorry i thought you were dealing with an OBD2 van originally.
If you can let us know if the EGR valve was the issue and what you did to fix eg. replacement/cleaning it will help others with the same issue.
Glad to hear the check engine light is now off.
Regards, Joe
Mar 24, 2019 at 5:18 PM
