Knocking/ticking sound from engine compartment
2007 MAZDA CX-9
190,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
SANDRA SUMMERS MIDDLETON
  • 5 POSTS
Whenever I accelerate, I hear a ticking/knocking sound from the engine compartment. This sound just appeared recently. I just had all spark plugs and three ignition coils replaced.
Jan 16, 2019 at 6:33 AM
Good morning,
Check the oil level to be sure the level is correct.
Can you upload a video of the sound so I can hear what you hear?
Jan 16, 2019 at 6:42 AM
  • 5 POSTS
I'll have to upload a video of the sound later. I did check the oil, it's low, so that may be my problem. It's an old car with close to 200,000 miles on it but I am not ready to give up on it just yet. Should I use the high mileage motor oil?
Jan 16, 2019 at 7:28 AM
No, just use the same oil you have been using.
Upload it when you can.
Jan 16, 2019 at 8:04 AM
  • 5 POSTS
My last oil change I switched to synthetic.
Jan 16, 2019 at 8:06 AM
That is okay, as well.
Jan 16, 2019 at 8:16 AM
  • 5 POSTS
Only makes this sound when pushing on gas and louder at lower speeds.
Jan 16, 2019 at 2:03 PM
That's an engine noise. You need to take it somewhere and have them listen to it and try to pinpoint the issue.
It sounds like you will need engine work.
Jan 16, 2019 at 2:08 PM
  • 5 POSTS
And just received a diagnostic code from my car on my cell phone of P0012.
Jan 16, 2019 at 2:31 PM
This is a code for timing components which makes sense. the noise could also be coming from there as well.
Get this checked at a shop. If it is, it will be expensive to repair. There is a lot of labor involved in this repair.
Jan 16, 2019 at 3:12 PM
STEVE W.
  • 15,113 POSTS
P0012 - That would be a camshaft actuator code stating the cam is over retarded. This can be caused by low oil/wrong oil. For oil I use whatever the vehicle calls for, especially on vehicles with ant type of variable valve timing.
I will say it is possible that if the engine oil has been conventional oil for a long time and you just switched to synthetic it could be a chunk of crud broke free and it caused the cam phaser to stick.
As Roy says, the best thing is to have someone listen to it while they are next to it. A rattle like you have could be camshaft related or it could be deeper in the engine. Very hard to say with a recording. However if it is that loud inside the car It's not something to ignore.
Jan 16, 2019 at 3:48 PM
