Front drivers side knocking sound going over bumps. Worse when colder out. Been to two mechanics who could not find anything.
Feb 28, 2018 at 5:02 AM
HARRY P
CERTIFIED EXPERT
Likely cause is worn out struts at that age. If you have a floor jack, you can put it under the lower control arm and jack up the car a bit. Then you simply try to move the strut up and down. If it moves more than about 1/4 inch, it is bad. The guide below is about replacing the lower control arm, but it is useful in that it shows you what the control arm is.
