Knocking noise and shaking engine
2000 TOYOTA RAV4
150,000 MILES • 2.0L • 4 CYL • AUTOMATIC
ZACH PAULUS
After accelerating down the road yesterday, mistakenly turned the overdrive "off" and tried to pass a slow-moving car. Engine revved up without gaining speed, then kicked back, followed by a loud repetitive knocking sound (as well as the check engine light flashing). Vehicle now continues to knock loudly whenever idling, and becomes noticeably louder when opening the throttle (accelerating/decelerating). Oil was low (so topped it off), and is still making noise.
Jan 18, 2017 at 12:27 PM
HMAC300
  • 48,601 POSTS
this may be a bearing problem as we cannot hear it have it. checked locally.
Jan 18, 2017 at 12:35 PM
ZACH PAULUS
Thank you for the prompt response. I do not believe there is a way to upload sound files on this site (I could be wrong). I am pretty certain the sound is coming from the engine, not from the body of the vehicle. I am also afraid to drive it all, so it will most likely have to be towed if it is going anywhere.
Jan 18, 2017 at 12:42 PM
HMAC300
  • 48,601 POSTS
well if you do not have any lights on the dash you should be okay to drive it someplace to get it checked. or if you can disconnect a spark plug one at a time and the knocking stops then that will tell you which cylinder it is.
Jan 18, 2017 at 3:27 PM
