It makes a knocking noise not sure where it's coming from friend says I blew a rod
Feb 12, 2016 at 5:32 PM
CATAFINA
CERTIFIED EXPERT
Where's is it coming from lower or upper end of the engine
Feb 12, 2016 at 8:27 PM
HMAC300
CERTIFIED EXPERT
if it's a rod knock sort out each cylinder one at a time as you disconnect spark plug wire the knocking should go away if it's a rod or piston. an upper end sound will be more of a ticking/light knock.
