Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Avenger
General
Noises
Knock
Knocking noise from the back end of the car
2008 DODGE AVENGER
148,600 MILES • 6 CYL • 4WD • AUTOMATIC
TINA PHILPOT
MEMBER
1 POST
FOLLOW
When driving i hear a loud knocking noise from the back end of the car. can that be a bad tire or something more major?
Apr 1, 2019 at 7:22 AM
JOETECHPRO
CERTIFIED EXPERT
Hey TINA PHILPOT,
Worn out suspension components are the most likely cause.
Also a loose wheel can cause this.
First thing to check is that your wheel nuts/bolts are tight.
After this you will need to check the rear suspension for play to find worn components.
Does it only knock over bumps?
Regards, `Joe
Apr 1, 2019 at 10:36 AM
