While driving suddenly lost power and the engine started making a knocking/loud ticking noise on the left bank?
2005 CHRYSLER 300
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
BOOSTISLYFE
  • 6 POSTS
I was driving to work when all of a sudden it lost power and the engine started making a knocking/loud ticking noise on the left bank of the engine. I heard it could be the rocker assembly. It does have some play it seems like just not totally sure.
Aug 2, 2023 at 3:27 PM
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. Also check the engine oil level to make sure it is clean and full.
Aug 3, 2023 at 11:27 AM
BOOSTISLYFE
  • 6 POSTS
It’s a short video. But this is when I got it off the tow truck and parked it.
Aug 3, 2023 at 1:43 PM
Thanks for the video. So, is this the engine running or is it you trying to crank the engine over? If you are trying to crank the engine over, it sounds like the battery is dead. It might have shorted out when driving and could cause the problem you are having. This guide can help us confirm the issue:
Aug 4, 2023 at 10:49 AM
BOOSTISLYFE
  • 6 POSTS
No the engine is running in the video.
Aug 4, 2023 at 4:40 PM
Okay, these engines had problems with the valve train, I would remove the valve cover on the side of the engine that is making the noise to check the rockers and valve lash. You are looking for excessive clearance. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Aug 5, 2023 at 10:14 AM
BOOSTISLYFE
  • 6 POSTS
Here’s a video of the rocker assembly.
Aug 7, 2023 at 7:49 AM
Thanks for the video. From what I saw the rocker seems to be okay. You might want to turn the engine over by hand to rotate the camshafts and check the clearance again. The movement that you show is normal. Also use a flashlight and check the valve springs to make sure none of them are broken. And while you are at it check the camshaft lobes for wear.
Aug 8, 2023 at 9:59 AM
BOOSTISLYFE
  • 6 POSTS
Found this on the other side.
Sep 6, 2023 at 3:00 PM
BOOSTISLYFE
  • 6 POSTS
No that was after taking that one off and why it was loose and coming off the valve.
Sep 8, 2023 at 2:15 PM
Yep, you found the problem, nice work, thanks for the video, let me know if you need anything else to fix the engine.
Sep 9, 2023 at 9:39 AM
