knocking
2002 MERCURY COUGAR
175,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
PENNYSTROHM
Car was running good. Needed a water pump, did not overheat kept check on water 100% of time. All the sudden after that once in awhile the oil light was coming on. Checked oil a little low. but time for oil change so go it changed and the oil light still periodically was coming on. Thought may sending unit or something. Well after about a week now it then started pinging on take off. Now has a more frequent (ping, knock). Had it looked at by two mechanics said to replace engine, two said to get a new (junk yard) head. then I guess will need a oil pump and what ever. Any ideas to be able to test or check exactly what it is? I know obviously very little about cars. Not a mechanic and cannot afford dealership for a 2002.
Oct 18, 2017 at 8:52 AM
MHPAUTOS
  • 31,937 POSTS
I would be doing an oil pressure test first. can you post the readings, at idle cold, idle hot and at 1500 rpm's?
Oct 18, 2017 at 7:32 PM
PENNYSTROHM
Where can I get this done or how?
Oct 18, 2017 at 8:10 PM
MHPAUTOS
  • 31,937 POSTS
You need a mechanical oil pressure gauge that will screw into the oil pressure sender port on the block, if you cannot do this any mechanic can do this simple test.
Oct 18, 2017 at 9:54 PM
