Okay, check engine light turned on. went and had the code pulled, it said one of my knock sensors were bad. i took the knock sensor harness apart where it plugged together and tested each wire going to the sensors. both tested 108 on the ohm setting on my meter. is that what it is supposed to read?
Feb 22, 2019 at 9:43 AM
