Okay, did he check and see if the signal from the sensor was correct? He needs an advanced scan tool that can read the knock sensor.
A simple test is to view the timing and take a small hammer and tap the top of the motor with it running. The timing should change on the scan tool. If it does, it is working. If it does not, it is not working and further checks have to be done.
Apr 2, 2020 at 4:59 AM
