Knock Sensor Code P0332
2002 BUICK REGAL
113,000 MILES • 0.8L • V6 • 2WD • AUTOMATIC
YMCDANIEL
  • 5 POSTS
If I use the code scanner in your video to erase the Knock Sensor Code - P0332, will I be able to get my car inspected without them seeing there was this code?
And, how long will the code stay gone, or check engine light stay off?
Nov 30, 2021 at 3:49 PM
No, that won't work. When you delete the codes, the system needs to complete an emission readiness test on each circuit related to the emissions system.
After reset, they will be able to tell because it will indicate, IM not ready. To reset the system's readiness, you need to drive the vehicle until, one at a time, they reset. If there is a bad knock sensor, it will trip the light again.
I don't know where you are located, but in PA, you can have one monitor not reset and still pass.
I hope this helps. Please feel free to let me know if you have additional questions.
Nov 30, 2021 at 8:36 PM
YMCDANIEL
  • 5 POSTS
Thank you for your help! In Texas I can have one code, but the check engine light has to be off. This is the only code, but I can’t get the light to stay off. Any thoughts or suggestions? Thanks!
Dec 1, 2021 at 7:54 AM
Has the knock sensor been replaced? Is the P0332 the only code present?
As far as the light, clear all codes and drive it until either one monitor is not reset. Hopefully, the knock sensor will be part of the last monitors to set. Once there is one left, get it inspected before the light returns.
However, please understand, the sensor may be part of the first monitoring system to reset and turn the light right back on.
Let me know if there are additional codes. Hopefully, we can just fix it, so you don't have to worry about the issue.
Also, take a look at the two pics below. Let me know if it is something you are comfortable doing. It is the diagnostics for the P0332.
Take care of yourself,
See pics.
Dec 1, 2021 at 6:03 PM
