I have had my share of these car issues before and was able to fix them. I had one before that was knocking on startup and i replaced the EGR, EGR cooler, updated intake, fresh coolant, new plugs and coils and some fuel system cleaner in the tank. This one here has same knock, i started with the plugs, injectors and coils, still misfiring and it moves from sometimes being cylinders 1, 2 or 4, randomly. I put it in maintenance mode and let it run for hours with fuel system cleaner in tank, still doing it. It can idle fine and run smoothly for minutes then all of a sudden It starts to knock then goes back to normal. Oh, i also changed the PCV, cleaned the intake, cleaned the EGR cooler and EGR. Same results, decided to replace EGR, same results, got another set of injectors same result. Coolant pressure test showed normal with no issues. And no coolant loss.
Not sure if the intake was not cleaned enough or if a really dirty EGR cooler can cause this.
Jun 27, 2023 at 3:52 PM
