Sam:
The reading indicates a lean mixture which usually isn't the oxygen sensor. The tech that watched how the vehicle was responding should be able to see how the o2 sensor is responding. Most times, there is an engine vacuum leak or even an exhaust manifold leak allowing unmetered air to get into the bank one system. Is it possible for you to have him scan the sensor to see if it is responding before you get a sensor?
Also, most times a sensor goes bad, the computer over compensates fuel mixture which would cause the opposite, a rich mixture. Before you purchase a sensor, see if you can have that done and let me know the results.
Okay, I'm going to get a bit technical so you know exactly what to ask for if you take it in. If there is something I say you don't understand, let me know.
Anytime there is a driveability issue, the first things to check are short-term fuel trim (STFT) and long-term fuel trim (LTFT). Fuel trim is an extremely important and a key diagnostic parameter which is helpful in many ways. It tells the tech what the computer is doing to control fuel delivery. STFT and LTFT are shown as a percentage. In a perfect world, you want the range being within 5% of 0. The 5% can be positive or negative, but that is normal. When it exceeds that, then questions come up. Positive fuel trim percentages indicate that PCM is adding fuel to the fuel mixture to compensate for a lean condition. Negative fuel trim indicates the PCM is trying to lean the fuel mixture to compensate for a rich condition. With that in mind, you should see a negative STFT beyond 5%.
Now, If I know what the SHFT and LTFT are, that will help me to determine the next issue.
Now for the O2 sensor. Testing O2 sensors is simple. The sensor needs to exceed .8 volt and drop below .2 volt. The change from low to high and opposite should be quick. Most times, a good snap throttle test will verify the sensor’s ability to achieve the .8 and .2 voltage limits. If the sensor doesn't react in that manner, it most likely is bad. Also, the high output should be when the fuel mixture is richest (when you snap the throttle). Once the throttle is released, it should snap back to the low voltage.
If the sensor seems non responsive, confirm there are no wiring issues and if not, replace it. Also, if it remains at a high voltage reading, create an engine vacuum leak to see if that changes how it responds. If it is showing lean and doesn't change, you can actually use propane to create a rich mixture, but I don't want you doing that.
________________
Why did I ask for the fuel trims and to see how the sensor is reacting? Between the two, I will be able to tell if the computer is doing what it needs to do and if the sensor is actually faulty. I'm hope you understand this. I'm trying to focus on what is showing as the problem now and to determine if it is the sensor or not. I know what another $150.00 is like. Especially when it gets spent unnecessarily.
______________
Please feel free to let me know if you have questions or need clarification. Also, let me know what you decide.
Apr 22, 2019 at 6:29 PM
