Shut off switch DIY installation
2016 HYUNDAI TUCSON
5,000 MILES • 2WD • AUTOMATIC
BRIGGS JHONNY
  • 11 POSTS
Good day.
How can i install a kill switch, either to the fuel pump relay or the ignition? Any help would be accepted.
May 6, 2020 at 12:45 PM
Any time you want to add a shut off switch to a component you need to interrupt the power supply or the ground.
I highlighted both wires. The way to do this is cut one of these wires and run a new wire for each side of the wire to a toggle switch. This way when you flip the switch on, it will complete the circuit but it will keep the circuit open when the switch is off. I diagrammed it on the last sheet using the ground wire but either wire will work.
Let me know if you have questions. Thanks
May 6, 2020 at 4:52 PM
BRIGGS JHONNY
  • 11 POSTS
Thanks Kenny.
May 6, 2020 at 7:25 PM
You are welcome. Please come back to 2CarPros in the future. Thanks
May 7, 2020 at 6:42 PM
BRIGGS JHONNY
  • 11 POSTS
Noted i will. Just awaiting the arrival of items ordered to proceed.
May 8, 2020 at 6:10 AM
BRIGGS JHONNY
  • 11 POSTS
Kenny good day. obviously the wires are connected to the fuel pump .. can they be sourced further forward to make the splice? Or just remove the rear seat and trace it FWD?
May 8, 2020 at 6:14 AM
Good question. You can do it anywhere on that wire. Where ever is convenient to make the splice. Just make sure you are soldering and heat shrinking the connections so that you never have an issue.
May 8, 2020 at 5:54 PM
BRIGGS JHONNY
  • 11 POSTS
Thanks Ken. All items ordered should arrive in a few days.
May 9, 2020 at 7:42 AM
Sounds great. Thanks for using 2CarPros. Please come back in the future if you need help with other things. Thanks
May 9, 2020 at 6:17 PM
BRIGGS JHONNY
  • 11 POSTS
Hello Kenny.
I have another question.
What about connecting a inline fuse and a relay to the circuit ?
Jun 4, 2020 at 7:32 AM
BRIGGS JHONNY
  • 11 POSTS
A picture showing the wire connector to the fuel pump.
Jun 4, 2020 at 7:47 AM
This circuit already has a fuse so you don't need to add another. All you are doing is adding a switch so the circuit is protected.
Let me know if you need anything else. Thanks
Jun 4, 2020 at 8:24 PM
BRIGGS JHONNY
  • 11 POSTS
Great . Noted.
Jun 5, 2020 at 6:31 AM
Let us know how it turns out or if you have more questions. If not, thanks for using 2CarPros.
Jun 5, 2020 at 7:49 PM
BRIGGS JHONNY
  • 11 POSTS
Dear Kenny.
Good day/night or morning.
Hope all's well. Please to inform you that switch has been installed 6 days now. There are no issues. All seems to be working great.
The diagram was an excellent starting point.
Thanks again and be safe.
J
Jun 14, 2020 at 6:48 PM
Great update. Thanks for letting us know and for using 2CarPros. Please come back if you need more info in the future. We will be here to help. Thanks again.
Jun 14, 2020 at 7:25 PM
