Raise and support vehicle.
Remove the wheel.
Set parking brake
Loosen and remove 4 hub nuts and screws
Release parking brake and remove wheel drum
Remove adjuster lever spring with a spring wrench or pliers then remove adjuster lever
Remove return spring with a brake spring wrench or pliers
Turn adjuster star wheel clockwise to relieve tension on shoes
Remove adjuster assembly
Turn hold-down pins until they align with groove in hold-down spring clips
Remove primary shoe and anchor spring
Remove secondary brake shoe with parking brake cable attached, then remove parking brake cable from shoe
Remove control lever C-clip and lever from secondary brake shoe
Disconnect brake line from wheel cylinder
Remove two wheel cylinder mounting bolts and remove wheel cylinder
Remove parking brake cable bracket bolt, then remove parking brake cable from backing plate
Remove 4 nuts from backing plate
Tap axle from behind with rubber hammer and then remove axle from housing
Remove backing plate...
This should get your rear drums and shoes off..
Jun 12, 2009 at 10:59 PM
