FRONT BRAKE ROTOR
Removal & Installation
Raise and support vehicle. Remove front wheels. Remove brake caliper. See FRONT DISC BRAKE PADS & CALIPER. Using a micrometer, measure brake rotor thickness. Using a dial indicator, measure brake rotor runout. Compare to specifications and resurface or replace as necessary. See DISC BRAKE SPECIFICATIONS. To install, reverse removal procedure.
May 4, 2009 at 6:47 PM
