2000 Kia Sportage Can't find plugs on my 2000 kia sportage
2000 KIA SPORTAGE
123,000 MILES • 4 CYL • 2WD • MANUAL
GETTIMAN
I have a 2000 Kia Sportage and need to change the spark plugs. It has a 2 liter 4cyl. 5 spd. manual. Can you help me find the plugs and maybe some directions on how to get to them, maybe some pictures to help. Thank You.
Jan 27, 2009 at 6:58 PM
DON OLIVER
  • 101 POSTS
Easy to find. on top of the engine is a black cover . remove it and you will see the intake plenum from the air cleaner to the intake. remove it and you will see a plastic cover about 3 inches wide the length of the engine. remove the screws and the plugs with the coils will be under it. remove the bolted on coils and the plugs will be under them. there are only two coils but you'll see the plug wires to the other cylinders. Good luck. easy fix.
Jan 27, 2009 at 7:12 PM
