1999 Kia Sportage Replacing The Timing Belt
1999 KIA SPORTAGE
87,610 MILES • 4 CYL • 4WD • AUTOMATIC
TAMMYSOU
I just went for an Estimate on replacing the Timing Belt in my 1999 Kia Sportage. I was told that in order to replace the Timing Belt the Water Pump would have to be removed and replaced as well. I was given a labor estimate of 539.00 just to remove and install a new water pump. In comparison the labor to remove and replace the Timing Belt was 115.00 in addition to the cost of Parts.
My question is does the Water Pump have to be taken off in order to get to the Timing Belt to replace it? Or are they just trying to take advantage of a seemingly helpless Female?
Apr 26, 2008 at 4:44 PM
Get out of that place or they gonna finish your purse. I've checked it out. see below timing belt removal does it say you have to remove the water pump in order to remove the timing belt.
https://www.2carpros.com/forum/automotive_pictures/12900_tbelt_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_water_pump_6.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_tbelt2_1.jpg
Apr 26, 2008 at 5:34 PM
