1999 Kia Sportage
1999 KIA SPORTAGE
DUANE FULTON
  • 12 POSTS
Engine Cooling problem
1999 Kia Sportage 4 cyl Two Wheel Drive Automatic
Asked about this last week and donated $10 Haven,t heard from technicians. Heard from one other customer???
Jun 10, 2010 at 5:02 PM
SATURNTECH9
  • 30,869 POSTS
That was a 2carpros tech you got a response from not a customer.Look's llike he is waiting to hear back from you and what you found.So go ahead and post a response to him on last week's post where you asked the question that way he will see your reponse.
Jun 10, 2010 at 5:12 PM
DUANE FULTON
  • 12 POSTS
Sorry about that misunderstanding. I hope I can continue to obtain advise as it is very usefull. I'll check the car out this weekend.
Jun 11, 2010 at 11:17 AM
SATURNTECH9
  • 30,869 POSTS
No problem no harm no fowl everyone get's confused sometime's even me lol.So when you check out your car send him a message he will be more then happy to help you out with it.
Jun 11, 2010 at 12:06 PM
DUANE FULTON
  • 12 POSTS
Still have a problem. Where is the exact location of the temp. sending unit? I'm looking just to the front of the oil filter bracket. I got a sending unit WT522 at OReilly I also confermed that this is the right one by looking it up. What I'm looking at on the car is a lot larger than the replacement. Also, is there a fan relay? I wouldn't know where that's at either. I suspect a bad relay?
Jun 13, 2010 at 10:10 AM
SATURNTECH9
  • 30,869 POSTS
I emailed you the best diagram i could find of where your coolant temp sensor is.I also emailed you how to test your cooling fan relay it tells where it is in the test.I emailed the information to your personal email.It say's your cooling fan come's on with your a/c does your a/c work?If so turn it on and tell me if the cooling fan come's on with it.Also did you check the cooling fan fuse.Let me know what you find.
Jun 13, 2010 at 9:39 PM
SATURNTECH9
  • 30,869 POSTS
Duane Fulton says> The air cond does come on. I checked the fuse,relay, and put in a new temp. sending unit. This weekend I'll check out the fan motor. Could be a bad wire somewhere.
saturntech9 says>So when you turn the a/c on and you said it work's does your a/c condensor electric fan come on?All so if you have a kia sportage it say's you have a fan clutch and fan blade not a electric fan for the radiator.So are you talking about the electric fan for your a/c condensor not working?Or your radiator fan not working which is not electric if you do have the sportage model.Let me know.
Jun 18, 2010 at 3:53 PM
DUANE FULTON
  • 12 POSTS
It turned out to be the fan motor. I got an email from you that someone changed my passyord? It wasn't me.
Jun 19, 2010 at 1:51 PM
SATURNTECH9
  • 30,869 POSTS
Glad to hear you got it figured out.I didn't send you a email saying someone changed your password could you foward that email to me so i can figure out what happened there.Thanks in advance for fowarding the email.All so thanks again for your donation and thank you for using 2carpros.
Jun 19, 2010 at 6:56 PM
