1997 Kia Sportage blows fuel managment fuse
1997 KIA SPORTAGE
165,000 MILES • 4 CYL • 4WD • MANUAL
PFSHEAF
has blown 15 amp fuel management fuse. will not start, cranks but wont run. no codes set. will run on eather. blows fuse repeadedly .fuel pump fuse ok ,ox sensor fuses ok. fuel pump runs when jumped at diagnoistic termenal under hood. have disconected, ingectors, massairflow, throttle possition sensor, cam and crank sensors,idleair control still blows fuses. have replaced ecu. no luck.
Oct 16, 2008 at 9:32 PM
KERENSELF
  • 54 POSTS
Hi there!
You would be doing yourself a disservice by trying to diagnose this without a wiring diagram. Most of your service manuals will have them in the back...With it, you can tell what components are protected by the fuse you mentioned. It appears that the fuse you are speaking of could be the MAIN fuse??
Keep in mind that fuses blow when the protected circuit draws more amperage than the fuse is rated for. Typically we are looking at a component on the circuit being bad (like an electric motor) or two circuits somehow crossing and pulling power through one source......With a diagram and voltmeter, you should be able to narrow it down pretty well. - this can be time consuming, however, and their are cases when paying a professional to fix it far outweighs the cost of your time and frustration. :)
Oct 16, 2008 at 10:38 PM
