1996 Kia Sportage fuel injectors
1996 KIA SPORTAGE
GRAPAPE66
Engine Performance problem
1996 Kia Sportage 4 cyl Four Wheel Drive Manual
cranks and drives fine but when i shut the engine off it will not restart. i was told there was a short or shortage in the fuel injectors. problem is there is one located at front and one to the rear of engine. how do i know which one is faulty? thanks 4 your time
Aug 24, 2009 at 9:59 PM
Check the fuel pressure if okay then now you check the injectors if its clicking while engine is being crank over if so its pulsing if not use a noid light on the injector harness and check for pulsing there.
Aug 25, 2009 at 5:36 AM
