1995 Kia Sportage no spark
1995 KIA SPORTAGE
LEEZY
Engine Mechanical problem
1995 Kia Sportage 4 cyl Four Wheel Drive Manual
there seems to be no spark coming to the plugs,could you please tell me what the possibilities that can cause this ..???
Jan 9, 2009 at 5:00 PM
DON OLIVER
  • 101 POSTS
you need to see if you still have a timing belt. if not the computer doesnt see the cams turning, and it will not have spark. if the cams aren't turning when cranking, replace belt and start it up.
Jan 29, 2009 at 5:12 PM
POLLYCRANOPILIS
It is not the cam sensor it will run without it but the crank sensor is more likely your problem
Jan 30, 2009 at 5:34 PM
DON OLIVER
  • 101 POSTS
silly question. has the unit been scanned yet? also does it sound normal while cranking?
Jan 30, 2009 at 6:11 PM
