2008 Kia Spectra Burning up Headlights
2008 KIA SPECTRA
36,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROCKETTTIM
I am having a problem with the headlights in my Kia burning out way to often. I have had the car for 2 years and have replaced the headlights 3 times and they just burned out again this morning. Kia has said that I need to buy their headlights to fix the problem. What can you reccomend.
Feb 5, 2010 at 9:02 AM
2CARPRO JACK
  • 11,533 POSTS
Is that vehicle still under warranty? If so take it in for blow headlights. Let them do the repair , then if they blow out in a short amount of time, it becomes their problem.Otherwise, buy their bulbs at the parts dept and install yourself and see if it does make a difference.Do any other lights in the car seem excessivly bright when the headlights pop? do they do it as a set or one at a time?
Feb 6, 2010 at 7:33 AM
ROCKETTTIM
It is still under warrenty, when I called the dealer he said he knows it's the after market headlights that are the problem so I am not sure. I am afraid if I waste my time taking it in because they aren't even going to look at it. They blew out one at s time at first and then both at the same times this time .
Feb 6, 2010 at 7:58 PM
2CARPRO JACK
  • 11,533 POSTS
If you have to buy bulbs, install theirs, then if they blow take it in under warranty... bulbs should last a very long time with no problems
Feb 6, 2010 at 10:30 PM
