Trying to replace clutch - have all bolts off, drive shafts removed and appears ready to remove. Can spread trans from engine about 2" all around using 4 pry bars held by three people. When you let pry bars loose the trans case will return back against engine. Reason for replacing clutch is that it slips in 3rd and 4th gears; otherwise car runs fine.
Oct 18, 2009 at 2:50 PM
