2004 Kia Spectra torque for front wheel bearing
2004 KIA SPECTRA
PUNK65
2004 Kia Spectra
I cannot get the rotor unseized with pb blaster or hitting with 10# sledge hammer. Would like to remove the wheel bearing but do not know how much torque is required when replacing. Can you please help?
Mar 7, 2009 at 8:10 AM
BMRFIXIT
  • 19,053 POSTS
Axle shaft lock nut is 154-204FT. LBS
Mar 7, 2009 at 8:18 AM
MERLIN2021
  • 17,250 POSTS
To remove the rotor, remove the two screws and pull, to do the hub bearing remove the knuckle and press, there is a tool, but you can use a hammer and correct size drivers to punch out the hub, then flip it over and remove the c clip and press the beaing off. or take the hub to a machine shop and pay the press chage, this is the best way to go!
https://www.2carpros.com/forum/automotive_pictures/62217_Kia_Clip_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_kia_Hub_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Kia_Press_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Kia_Race_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Kia_Tool_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_kia_Rotor_1.jpg
The other thing is if you have less than 100,000 miles, it should be covered at Kia!
Mar 7, 2009 at 8:28 AM
