CAUTION: Do not attempt any maintenance on spark plugs if engine is hot.
Removal
Disconnect negative battery terminal.
Carefully remove high-tension leads.
Use compressed air to blow any dirt or debris from around spark plug hole.
Check that spark plug fits squarely in spark plug socket and remove spark plug.
Installation
Install spark plug into cylinder head. Tightening torque: 18 - 22 lb.ft (25 - 30 N.m, 2.5 - 3.0 kg.m)
Reconnect high-tension leads.
Reconnect negative battery cable.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jul 22, 2010 at 9:44 PM
