REAR COMBINATION LIGHT ASSEMBLY (4 DOOR)
BULB REPLACEMENT
Disconnect negative battery cable.
Disconnect electrical connector from light assembly.
Remove two mounting screws and two nuts from combination light assembly.
With bulb holder disengaged, pull bulb holder carefully forward relative to vehicle, and remove from light assembly.
Remove bulb as required from bulb holder.
Install new bulb of proper type, as shown on bulb holder.
Position bulb holder on light assembly and press to engage with light assembly.
Install combination light assembly by positioning slightly toward outside of vehicle and sliding inward into position.
Install two mounting screws and two nuts.
Install electrical connector.
Connect negative battery cable.
ASSEMBLY REMOVAL
Disconnect electrical connector.
Remove two screws and two nuts attaching rear combination light assembly to vehicle.
Remove light assembly.
Mar 17, 2009 at 6:35 AM
